Zwift Click and Zwift Ride
Does Zwift Click work with Zwift Ride? Is it too many BlueTooth connections along with heart monitor, cadence, controllers, resistance, and power source?
Yes, I believe you can use a click as a secondary shifter alongside the zwift ride’s controllers.
Apple TV is probably the only platform that would have a problem with too many Bluetooth connections (unless you pair via the Companion app). Depending you which trainer you have, you may also be able to bridge the HRM via the trainer to reduce the connection count by one. If you use the trainer for all of power, resistance, and cadence, then that’s usually one connection.
You might also find this useful info:
Michael,
Thank you for your prompt response.
Greg
