Imposible Good pairing Zwift player with Apple TV, My HeartControl, always error. And pairing with My phone.
The Apple TV only supports three Bluetooth connection, and one of them is the ATV remote.
So typically the trainer is one connection, so you can’t connect both Zwift Play and a HRM at the same time, unless perhaps you have a trainer that can bridge the HRM signal.
Pairing everything via Zwift Companion on your phone doesn’t have the same limitation,. and it’s what I do myself for my ATV and Zwift Play.
I Connect all with se Companion ! That is the problem, and alway the same problem…. The HRM always and conection. That is the raison ni moré connect my ZPlayer. What is ATV?
ATV = Apple TV
Hello @Myque_Penaranda welcome to Zwift forum.
Inconsistent Bluetooth pairing behavior on Apple TV can sometimes be fixed by powering off / on the Apple TV. When is the last time you rebooted?
If your trainer is paired reliably and only your heart rate monitor is acting badly - have you tried replacing the battery in the heart rate monitor?
