Zwift hub and play controller
Hi all
I have just purchased a used zwift hub with play controller
I use apple TV for zwift I have bridged HR monitor to save a bt connection
When I try to connect play controllers it appears there are a left and right demanding a bt connection each
Which forces me to use comp app ?
I was hoping this wouldn’t be case
Am I correct?
Regards Dave ( mountain hippo)
Correct, that is one of the limitations of Apple TV. Play controllers are two separate devices. In the Zwift Ride frame the controls are one Bluetooth device.
Thanks Paul I have a jet-black victory on order with it’s own WiFi will I still have a similar issue ?
No that should allow you to avoid the Apple TV Bluetooth limitations
Brilliant news thanks Paul
