Zwift Calibration problems with Elite Suito
I had exactly the same problem with Zwift calibration on my suito however I calibrated through the elite app in the end and it was fine
Hi, After much frustration with trying to calibrate in Zwift, I finally figured out how to do the calibration of my Elite Suito with the MyEtraining App. I have a result of 12490. What does this mean? Do I have to enter this somewhere in Zwift?
I bought an Elite Suito-T the other day and ran into calibration issues. I thought my experiences might be helpful.
The Bad
I used the Zwift calibration to start with (the spanner icon next to the trainer in the pairing screen) . It showed me a 5 step screen and told me to pedal to 37kph and then stop. I did this and was met on screen two with a notice to keep pedalling, which I did at 40kph for 40 minutes :smiley: I gave up at that point and tried the Elite app.
Remember that Bluetooth on your phone can only pair with one item at a time, so don’t be connected to Zwift via Bluetooth at the time you try the app. I paired to my trainer but the Elite app calibration told me to keep pedalling. Increase the speed it said. I got to 60kph before it told me I had failed to reach the necessary speed. Anger ensued.
The Good.
I have a Huawei phone and apparently the app doesn’t sit well with it. I was able to calibrate very, very quickly with a borrowed iPhone. Also, I rode around for 15 minutes and have the Zwift calibration app another go. When it asked me to reach 37kph, I blasted it to 60kph and then TADA!! It told me to stop pedalling. Calibration successful.
I hope that helps someone. If In Doubt - Flat Out. :slight_smile:
use Elite eTraining app to calibrate their trainers, not Zwift
the number it spits out, compare it to the sticker on the bottom of ur trainer, should be within +/- 5 points or ur trainer is busted.
Hi Zwifters,
I’ve got the same problem. There is mistake in unit type. I think there should be 37 mph, it means 60 kph. I reached this speed, and I received the command stop to spin. After the message calibration finished.
Pawel
most people are not capable of hitting those speeds on a bicycle so yea…
I had the same problem when connecting my Wahoo elemnt Bolt.
Seems like Wahoo and Elite are not compatible…
