Any news about the issue? Xp still at 1x speed here.
Has anyone actually checked this in-game?
I just finished a stage of the TdW and thought Iâd specifically check the XP accumulation. I looked at my XP level before completing the next km, rode the next km and got the little +20 xp indicator on the HUD and then checked my XP level again and it had gone up by 40 points.
It looks to me like the indicator is showing only +20 xp instead of +40xp (+40xp during the TdW instead +60xp) but you are actually accumulating +40 (+60 during TdW I presume but I havenât checked that) and you can check this by looking at your xp total.
Mind you, heaven only knows whatâs happening if youâve hit level 60.
Thatâs exactly whatâs happening. You are still accumulating your accelerated XP as per the levelling up notion.
Itâs simply that the display isnât showing this. What i canât give an assessment of is if the orange bar is progressing at the correct rate. If not itâll be jumping a fair bit when the issue is corrected.
Yep, itâs just a visual thing.
Can you check whether this is really the case? Currently the problem is occurring again. For me anyway. I had the âvisual bugâ during TOW but seeing as xp was accumulating correctly then no problem for me. Now, since the update, Iâm not getting xp for accelerated levelling. Iâve been on to support but I still get the unhelpful link to âtracking your rider scoreâ.
Couple of things to check John.
- Have you looked at your XP before and after you go through a mile/km marker and manually calculated how much is being added.
- Is there any possibility youâve come to the end of your accelerated XP period?
Stuart
Yes I checked the progress bar to verify that Iâm receiving only 20xp per km. Also, can confirm that I have exceeded the xp requirement for level 60 so should still be levelling up on accelerated plan. Pause screen also shows accelerated levelling is still active.
John
John,
Checked this today and youâre right.
Iâm wondering that once you max out on levels it reverts to normal XP.
Probably no point in receiving accelerated xp if youâve nothing to accelerate to?
Rider score would show normal XP growth (because itâs your overall).
Levelling score (ie how fast you get to level 60) should be accelerated.
Is that what is happening?
(NB. Above is if you are on 1.34)
Makes sense.
In that case itâs working as it should as far as i can tell.
Stuart
I think you misunderstood. Iâm at level 56 and still on accelerated levelling. I currently have about 930,000 xp banked so certainly should be receiving additional xp. Iâm not. Quite frustrating
John
We have an issue (apparently this is a feature) where you are shown single xp being credited but you actually receive double. Itâs a visual issue.
The confusing part is that there are essentially two scores. Your levelling score (which you canât see after 1.34) and your rider score (which you can see after 1.34).
Stuart
I am not receiving the double xp. I have to be clear on this. I understand that previously there was an issue where the notification showed â20xpâ or whatever but in the menu I can see it credited double xp. This is not the same issue. I am not getting the correct increase in xp
John
for someone over level 60 is the levelling score always going to be 750000 (until new levels)?
Yes, but your pause screen will show your actual XP.
Same here, I should have accelerated XP towards lv60, and I know I got 40xp per km on the pause screen despite it says +20xp at the top of the ride screen - before yesterdayâs update. Unfortunately, after yesterdayâs update itâs not the case - it only gave me 20xp per km when I double checked on the pause screen. It is clear that some different problem came up with the latest update.
The pause screen will show your total XP (not level XP) which should not give double XP.
If you are on 1.34 or later.
Wah, thank you, that explains everything. I should have read this thread thoroughly.
It is pretty confusing!
Hi.
Iâve been reset to level 50. And received no xp on todayâs ride.
Atv. Up to date.
