Hi
I have a work laptop with administrator rights but I still got the error “failed to login check internet connection” when trying to log in the first time
What can I do to fix this error? Is there a setting that I should change?
Thanks in advance
Thomas
Are you using a VPN on that laptop? That can be an issue. Alternatively your laptop might have certain network ports locked down that Zwift needs
Locked-down work laptops can often refuse to play nicely with Zwift.
I have tried it with and without the VPN but no luck
