Zwift app on Work-maptop with microsoft "failed to log in. Check internet connection"
Hi
I have a microsoft laptop from work with admin rights. Unfortunately, Zwift can’t connect to the internet whilst it is connected to the internet with Wifi
I get the following errormessage “failed to log in. Check internet connection”
What settings should I change to be able to use the Zwift application on my laptop from work?
Thanks in advance
Thomas
Are you running a VPN? It might be that you have some of the network ports locked down that Zwift needs to function. Check if you can override the firewall settings.
Required network ports are documented here:
