Considering riders doing vEveresting attempts who’d want to minimise their time and just repeat ADZ without going the end of a route to reset it. Does anyone know if you can get the segment map from just doing a u-turn a the bottom of ADZ?
Not necessary to get the pop up segment map but it’s definitely a big plus to have it during something like a vEveresting.
On far right hand side of the image in case my description isn’t clear
Yep, Gerrie is right. Go down till you hit the dirt (or when the turn signal pops up), then make your u-turn. You will see the map reset. Thus, you will get credit toward your 5 and 25 alps as well as reset the spinning wheel at the finish. Strava will count each climb regardless, as will the total elevation. But for just a few seconds longer downhill, you will get all the benefits of the map and timer. Let us know when you are going for it. You may get some ride-alongs and especially some encouraging 'ride-on’s.
As of today June 21, this has been fixed. The map and reset and everything seems spot on after the update.
Thanks team Zwift!
They also state that they are working on the rest of the known bugs.
Times ahead and behind riders is a separate issue.We’ll have to wait on that one.
