Wattbike Atom Gear Shift Problem
Warm…off the press! App Store yesterday has new app with new firmware…
New firmware released from Beta which apparently solves many of the issues.
Finger’s crossed.
How are you getting on Mike. Are you having the same bugs and can you see fix coming soon? Thanks
Ooh that’s interesting, where did you get that from? Would be great if there is a fix. Fingers crossed then. Thanks
Asked about the update you mentioned and got this back:
The first major Wattbike Atom firmware update has arrived.
V1.02.00 (Atlas) makes changes to the Atom’s ergo and gear algorithms for an improved ride experience. Based on user feedback, and in our pursuit for continuous improvement, we’ve paid particular attention to resistance when using ride simulators such as Zwift. The update also improves sensor connectivity for Bluetooth and ANT+ heart rate monitors for easier pairing.
The core of this update has been tested by our beta user group, and feedback has been fed into the Atlas firmware.
To experience our latest firmware, just connect your Wattbike Atom to the Wattbike Hub and start a ‘Just Ride’ session. This will prompt the automatic update.
If you’re currently using the beta firmware you can continue to use this without updating if you wish; the new beta firmware has some further tweaks and fixes.
Sounds very promising.
Has the firmware update worked for anyone, as of yet?
I upgraded the Wattbike to the latest firmware and made sure everything else was up to date. I also made sure that Zwift was the only app running on the iPad when I started Zwifting. Sadly, I can report that the gear shift display problem is still there. Changing gears up or down briefly displays the gear you are in then displays Gear 4. To be clear, the gear does actually change and the resistance actually changes so this is definitely a display problem at Zwift’s end rather than an issue at the Wattbike Atom end.
There is a work around. Start a ride in Just Ride mode, stop pedalling, get off and switch the Wattbike Atom off. Wait 10 seconds until Zwift loses connection to the Atom and then switch the Atom back on again, when Zwift reconnects to the Atom, the gear display problem is now fixed. I didn’t have time to test how that works transitioning from erg mode to ride mode due to a lack of time. However, this indicates to me that the issue lies in Zwift’s initialisation code during Bluetooth connect when the app starts rather than an issue with the Wattbike.
Hope this helps.
  • Wattbike Atom firmware 1.02.00
  • Zwift Version 1.0.37240
  • iOS 12.3.1 running on iPad Pro
Hi there, I updated successfully yesterday however the Gear 4 problem is persistent, exactly as before.
I hope Zwift offer you a job. :smile:
Is there any word on when Zwift will address the “Gear 4” issue ? its not stopping me riding but it is quite annoying
It is. I’ve provided as much info as possible to Zwift but it has been months…
I updated with the latest Wattbike patch and not only is the gear 4 issue continuing but now mid ride the Wattbike is automatically dumping gears down to gear 1. Unless this fixed, this is becoming almost unridable on Zwift
Same problem here. Gear 4 issue, and wattbike cycling down to gear 1 intermittently. Zwift pretty much unusable… switching to trainer road until they fix this.
would encourage everyone with this issue to complain via the support functionality. Certainly in Aus this is a breach of consumer law - the product doesn’t do what it’s advertised to do.
Does the bike actually move down to gear 1? If so, I’ll hold off installing the patch. I’ve emailed support again about the ongoing gear 4 issue.
Can anyone suggest alternatives to Zwift, ideally for iPad, but failing that for PC?
Hi
I’m having a similar problem with the right hand shifter - say i’m in gear 10 and then come to a hill - want to change down (obvs) and when I move down 1 gear - it often shifts all the way down to gear 1 (which isn’t great - particularly when i’m in a race) and then doesn’t let me move up (i.e keeps going back down to 1 no matter what I do) - eventually it plays ball and let me change gear, by which point the group I was in has long gone…I have changed the battery and tried a few things
but nothing seems to work. Any ideas as it is becoming v frustrating…(to say the least).
Soon after I got the Atom in January, I experienced the behaviour of it shifting down to gear 1 and then when I shifted up a gear it immediately shifting back down to gear 1 again… I found that my problem was caused by the shifter cover riding up and occasionally putting constant pressure on the “down gear” button. By rolling up the shifter cover and then pulling the entire cover down really tightly over the shifter itself, then rolling the cover back down, I sorted the issue and I haven’t have it come back since. If you’ve not tried this, it’s definitely worth a go.
Incidentally, I’ve been using the beta firmware since February and I found it improved the shifting response a lot, so I’m glad that they’ve eventually incorporated into their recent release! I see in Wattbike’s announcement that there are further tweaks and fixes in their beta branch, so I’ll be sticking to that! I also saw another post where Zwift reported that they’ve identified the bug behind the erroneous display of “gear 4” and the fix will be in a future update (although TBH I’ve got so used to this that I almost don’t notice it). What I do still get occasionally is complete Bluetooth dropouts (connecting to a Apple Powerbook), where the sensor screen shows it is connected but “No signal”. Very frustrating and sometimes needs an Atom power cycle to make it connect again. Has anyone else experienced this???
Hi Steve, I went into the Wattbike Hub and disconnected the right hand shifter and connected the left hand shifter as the right hand shifter, if that make sense. My wattbike is working perfectly now and with the new update a few weeks ago, is awesome for zwift racing.
Having updated Zwift to the new build at the weekend, I can report that the Wattbike gear shifting display problem is not fixed. Still the same (although now sometimes it displays gear 106 (!) or gear 214 (!!!)).
Occasionally Zwift loses synchronisation with the Wattbike and displays 0 cadence and power. This lasts for about 10 seconds before it resyncs up and you can ride again. This all happens in a free ride configuration: workouts don’t appear to be affected.
Come on Zwift, I reported this on May 11th. Surely you should have a fix now. For what it’s worth, the wattbike works perfectly with other training systems (and their own app) and it’s getting to the point where I might as well switch to them rather than using Zwift.
Still having the Gear4 display problem and it is Aug 1st - any sight of a fix?
As of the latest update (which included the Titan’s Grove expansion), the Wattbike problem appears to be FIXED!
Obviously this is only with my setup but hopefully Zwift have fixed the problem for everybody. I don’t know if there’s anybody from Zwift support who could give us an explanation of what caused the problem? This would be interesting for the computer geeky cyclists out there like me.
Thanks for fixing it Zwift. Nice to have everything working smoothly again.
