Using Companion as a 'Bridge'
Hello all,
I use a Tacx Flow Smart trainer which should provide me with the cadence, however it’s recently stopped working. That said, it still appears in my Companion app. Therefore, what i’m trying to do is use the Companion app as a bridge as advised by Zwift Support. But the advice i’m given is to go into setting when using my main login, which in this case is an Ipad. However, the Ipad does not have any settings icon on the main page.
Anyone else encountered this issue? Any help would be greatly welcome.
I don’t believe you can use ZCA as a BLE bridge to an iOS device.
I had a similar problem with my Assioma pedals recently. However, once I paired them as a power source (where they did appear), they showed up as a cadence source.
Hi, I’ve been using the Tacx Flow smart trainer for over a year and I just had my first cadence drop in the middle of a training ride. It was strange as the power was still being reported. Regardless, it messed up the ride. I don’t know whether this is a one-off, or an omen of things to come. I will do my next ride as if this never happened.
My question is this: Zwift support says to use the companion app for cadence. If I use the companion app to display cadence, will it support ERG mode training?
