great stuff! I was working one too so will look at adding info to your template maybe. Quick note: 8lbs isnot 17 kgs. Think you meant the opposite. Also power and cadence are in top left, not right. Cheers!
You should add something abut the .fit files being saved locally in the documents/zwift/activities folder. I see this question come up most often in the support forums.
…and that riders moving erratically on the road, or running off road, typically indicates that the erratic rider is having either network difficulties or has a low-end video card with a sub-par frame rate.
Tried to email too. I have also created a web version of a user manual. But it’s rather picture heavy at www.titaniumgeek.com. If you’d like to combine them, please email me through the site
Level 8 was the Zipp 404 wheels. I just hit level 9, which unlocks the regular camo jerseys (as opposed to level 11, which unlocks the digital camo jerseys).
Brian, if you want to add me as a contributor / editor as well, I would be happy to help. I have experience writing FAQs and user guides, in addition to being a stickler for language.
I’ve never gotten the listed F1-F10 commands to do anything noticeable in the application. Do they really work? Is this document current? There’s nothing listed past Level 15, for example; and when I got an achievement for 500 watts, it had a different name than listed in the document.
