Training Peaks Custom Workouts Not Syncing [March 2022]
same for me, the new update might have broken something
So I’ve spent this evening recreating as many of my TP workouts manually in the custom builder on the Zwift app.
They’re showing up in the Custom section under “Workouts” but I haven’t tried to ride one yet.
This is the best solution until Zwift fixes this problem.
(The .zwo file import to the Mac OS folder from TP directly or by email drag and drop still doesn’t work so the problem seems to be the TP server interface to source folder READ/LOCATED by the Zwift app rather than using the Zwift app builder function which places the workout properly)
I still have a hunch that this is an Apple issue. I run Zwift on my PC/laptop and import without issue. If I had an issue using an Apple platform, I’d try bypassing it, but maybe folks are trying that without success.
Same Problem here; Please fix it!
Thanks.
Hi Worked for me last week. Just wanted to start my wokrout right now. Not finding my workout or even the TP dropdown…
Any issues currently?
Paul
I have been experiencing this same issue since the beginning of January. Before Christmas my workouts were syncing, but it’s now stopped doing that.
I’ve tried disconnecting and reconnecting Zwift and Training Peaks in both directions - and each are paid subscriptions - but nothing works.
Any other suggestions?
I was having the same issue, but eventually figured out how to resolve things syncing from TP into Zwift. My coach was building workouts that were categorized as “% Threshold HR”. You’ll see this in the “units” drop-down within TrainingPeaks.
In order for the workouts to appear I needed to change the “units” to reflect “% of Functional Threshold Power” or FTP.
Once I saved and updated my workout in TP it now appears in Zwift on both my iOS and AppleTV devices
I don’t see the unit dropdown you’re describing. Can you be more specific on how to change this?
If you you have your TP workout plan in HR zones it may not work (like my case and many cases in here), I change specific workout in TP from HR to Power and it worked! Now I can see it in Zwift.
The way to do that it is shown in this video in Youtube: " How to Change Workouts from Power to Heart Rate in TrainingPeaks" (it changes from Power to HR instead, but the steps are the same to change it the opposite way):
Another important thing to mention is that Zwift will only show the workout scheduled on that day in Training Peaks, so make sure you are matching it (or moving it to the appropriate date) in Training Peaks Calendar.
Hope this helps.
Is anyone having trouble with custom workouts not syncing on iOS today? Neither mine or my coaching clients showed up (no trainingpeaks custom folder) today after several reconnections between zwift and trainingpeaks as well as checking to make sure the workouts are written in %FTP and duration. In the past it was worked just fine. Is there a bug today?
me too! after this last update I can’t get my TP workouts to sync to zwift. have tried reconnecting etc but nada!
Haven’t been able to find my training peaks custom workouts in the zwift workout drop downs for weeks. Disconnect/reconnect didn’t work.
However, I just put a title in my workout for today and it miraculously popped up! Open Tp, edit wornout for the day, add title… save. Really silly if that’s the issue here … but give it a shot if you’re still having troubles. Worked for me!
This is happening to me also. I’m so frustrated and have spent 30 minutes trying all the trouble shooting and it’s not working. This is messing up my training schedule! Please help Zwift!
Does not work on Garmin…
Today i did a Workout. Perfect sync to Strava, but no sync to Garmin.
This is only if i do a workout on zwift. Everything else perfect sync to garmin.
