Hey David, I am having the same problem ever since the last Zwift update. I’m using my Tickr Fit via Bluetooth to my MacBook. It has been working fine for several months, but after the last update it is very inconsistent in connecting/being discovered. My other sensors are wahoo (Kickr / Cadence) and all work fine.
It is getting really frustrating. Every time I try to get on Zwift it takes 5-10mins to try and get HR reading, and sometimes doesn’t work at all.
I’ve checked with our dev team, and they’re aware of this issue and currently working on a fix. While there isn’t a workaround for this issue yet, the fix will come from our end, so all you should have to do is keep your game client updated. We appreciate your patience and understanding as we continue improving Zwift.
Good to know! thanks for the update. I also submitted tickets to both Zwift and Wahoo. Hopefully this fix is coming soon. Can’t hurt to keep the pressure on.
I’m back to using my old Tickr HR chest strap, which connects immediately. Weird.
I have been going back and forth with Zwift support for several months. We still haven’t found the cause of the problem. They think it is because I am using an older (2013ish) MacBook Pro - but this doesn’t really explain why it stopped after an update.
A temporary workaround is to connect your sensors through the Companion App. This works, though I don’t like it as a long term option. I’ve ended up switching back to my Tickr chest strap instead.
After latest update on AppleTV, my Wahoo TICKR HR won’t connect, even though it showed as “connected” in the Wahoo app. So I know it’s working, ZWIFT just isn’t seeing it. My KICKR and cadence sensors connect fine.
How are you connecting the Wahoo Tickr to the Wahoo App? If you are using Bluetooth than that is the reason your ATV connect find it, Bluetooth only allows one connection at a time.
