Supertuck animation broken? Avatar pedaling when cadence is 0 [April 2026]
To add additional information for mine - Tron bike and MacMini M2.
I’ve seen the pedaling animation when at 0 cadence and power when on a TT bike as well. Only at higher speeds / steeper declines.
It super tucks just fine when I’m not on the Tron.
I’ve noticed the same thing on the MX Rider (which may not have had supertuck in the first place). When I meet all the criteria for a supertuck, my avatar is pedaling. If the route then levels out so the descent no longer qualifies, my avatar stops pedaling, as expected. I would have expected the avatar to either supertuck when all criteria are met, or to stay motionless if the supertuck animation is not available on that bike.
I saw this behaviour yesterday when descending the climb portal on a TT bike, I had actually gotten off the bike for the descent and as the speed picked up my avatar started pedalling again
Went down the alpe today on a specialized bike and super tuck worked. My previous failure was Tron in the climb portal.
I also did some tests of this today on the Specialized P74, supertuck on and off multiple times and it worked, the only issue was one point where supertuck stayed on when the gradient and speed were too low for supertuck, but I’ve seen that before.
Has The same problem after 1.april. Am using The Tron. Have reported it a weekend ago, still no supertuck , miss it​:winking_face_with_tongue:
Cannondale R4000 on the steep downhill side of the Zwift KOM, 60+ KPH, 0 cadence/power and my avatar was happily pedaling away
I first encountered this on Big Spin Mayan San Remo March 24, once finished the climbs and headed down Oh Hill No, avatar would keep pedalling, zero cadence and 0 watts, I was also on a TRON that doesn’t show supertuck visual like other bikes
had it again earlier on the TT bike coming down the climb portal
I did not have the supertuck while descending the Hilly KOM on the TRON yesterday. Power dropped to zero. Pedals still turned. No one was in front of me.
The TRON does not show a supertuck animation
I believe you are incorrect.
I’ve been upgrading the TRON, and the avatar supertucked many times prior to this bug.
Yeah, the Tron did show supertuck before, what the Tron doesn’t show is the “in the draft” sit-up.
