Can no longer get into super tuck
It’s been about one week? I never had an issue with this but can’t figure out why this is no longer activating. Even if I am going like 75kmh at a grade of minus 7 and stop pedaling for 10 seconds it still will not go into Super tuck. Has anyone had this issue and where you able to fix it.
Did you swap to the TT bike? I don’t know for sure, but I’d assume there’s no “supertuck” animation for that.
No have been using a Tarnac for awhile. Yesterday I changed to a Cervelo to see if it would help. No change. Currently using Zipp 808
Do you have a cadence meter paired? Did both cadence and power drop to zero when you stopped pedaling?
Good question. Will be doing stage 5 tomorrow and will keep an eye on that. Thanks and I will let you know.
So during the stage I was going above 70kmh and the grade was around minus 10. I stopped pedaling for about 10 seconds. Cadence went to zero but power never went below 50. Now I need to figure out why it did not go to zero for my watts output. Using a Kickr.
Hmmmm, puzzling.
Do you cut the power to the Kickr between sessions? Have you performed a spindown recently? What platform are you using and how do you pair the Kickr?
Edit1: Did you happen to be doing and/or finish a workout immediately prior to trying to get into the supertuck position?
Edit2: Nevermind about Edit1… you said you were doing Stage 5.
I know it’s a while ago, but did you find the reason for this issue, and did you resolve it? How?
