Martin_Demers
(Martin Demers - Equipe Vertige)
December 11, 2017, 2:30am
#1
Hello,
I installed the Zwift software on my PC (Windows 10, with upgrade).
I can login to my account but when I click the Ride button, the home screen disappears after 5 seconds.
By referring to the log file. I do not see an error message.
Thank you for your help,
[21:21:00] Log Time: 21:21:00 2017-12-10
[21:21:00] Game Version: 1.0.22143
[21:21:00] Launcher Version: 1.0.39
[21:21:00] Loading WAD file ‘assets / global.wad’ with file.
[21:21:00] Loading WAD file ‘assets / environment / ground / textures.wad’ with file.
[21:21:00] Loading WAD file ‘assets / UI / WhiteOrangeTheme / WhiteOrangeTheme.wad’ with file.
[21:21:00] Loading WAD file ‘assets / UI / minimap / minimap.wad’ with file.
[21:21:00] Loading WAD file ‘Assets / UI / WhiteOrangeTheme / Scotty / Scotty.wad’ with file.
[21:21:00] Calling initialize_zwift_network ()
[21:21:00] … return value = 0
[21:21:00] End ZNETWORK_Initilize ()
[21:21:00] Successful audio init!
[21:21:00] Loaded audio banks
[21:21:00] Initializing graphics window of size 0 x 0
[21:21:00] Attached Monitors:
[21:21:00] monitor found at: 0,0
I would guess it is you video card causing the issue, make sure the drive is updated.
I have had this same problem in the past on a Windows10 PC.
It came about after changing the settings from ‘window’ to full-screen. I then had the problem of not being able to access the setup screen (to change back to a window) before Zwift dumped me.
I had to manually edit the /zwift/prefs.xml file and change the full screen option to window. The options are 0 or 1.
May not be your problem but worth a look.
As an aside, I recently had cause to try changing back to full screen (a different problem) and the original drop-out never occurred - go figure!
Martin_Demers
December 12, 2017, 2:10am
#4
My prefs.xml file is corrupt. What should this file contain? Do you have an example?
Thanks for your help!
Martin: you can delete prefs.xml. Zwift will create a new one. If you want to be cautious, just rename the prefs.xml.
This is an example of what one of my old prefs.xml file contained (it has a few more lines that contain name and email …)
prefs.xml is a text file so open it with notepad.
<ZWIFT>
<SPORT>0</SPORT>
<DEVICES>
<LASTCADENCEDEVICE>8044613</LASTCADENCEDEVICE>
<LASTPOWERDEVICE>768348</LASTPOWERDEVICE>
<LASTCONTROLLABLETRAINER>768348</LASTCONTROLLABLETRAINER>
<LASTTRAINERDEVICE>2988306591</LASTTRAINERDEVICE>
<LASTHRMDEVICE>7873322</LASTHRMDEVICE>
</DEVICES>
<CONFIG>
<USER_RESOLUTION_PREF>1920x1080</USER_RESOLUTION_PREF>
<FULLSCREEN>0</FULLSCREEN>
<LANGUAGE></LANGUAGE>
<LAST_POSTRIDE_GRAPH>0</LAST_POSTRIDE_GRAPH>
<ANNOUNCER_VOL>1</ANNOUNCER_VOL>
<TRAINER_EFFECT>1</TRAINER_EFFECT>
<METRIC>1</METRIC>
<PREFER_NATIVE_BLE>0</PREFER_NATIVE_BLE>
<LONDON_ROUTE_SIGNATURE>3276403604</LONDON_ROUTE_SIGNATURE>
<LONDON_BRANCH_PREFERENCE>6</LONDON_BRANCH_PREFERENCE>
<RICHMOND_ROUTE_SIGNATURE>1638640398</RICHMOND_ROUTE_SIGNATURE>
<RICHMOND_BRANCH_PREFERENCE>6</RICHMOND_BRANCH_PREFERENCE>
<ROUTE_SIGNATURE>3395698268</ROUTE_SIGNATURE>
<BATTPREFS>0</BATTPREFS>
<PREFERRED_MONITOR>2147516416</PREFERRED_MONITOR>
<BRANCH_PREFERENCE>6</BRANCH_PREFERENCE>
<IMGPREFS>0</IMGPREFS>
<AMBIENT_VOL>1</AMBIENT_VOL>
<SFX_VOL>1</SFX_VOL>
</CONFIG>
The <FULLSCREEN>0</FULLSCREEN> line I changed from 1 to 0.
As you can see prefs.xml contains the settings used on the last ride.
As Steve has stated, the file can be deleted, Zwift will create a fresh one. And as Steve mentioned, copy the file to the Desktop or rename the file if you’re, like me, super cautious
Martin_Demers
December 13, 2017, 12:56am
#7
Thanks for your help, but I’m not able to set problem.
I click Ride button and I have this screen (slide images) and after 5 seconds, it’s disappears.
I erase prefs.xml file and when I open Zwift, the new file name is : prefs.xml.INVALID.
I use Educational Windows 10.
Have you tried uninstalling Zwift, deleting everything in the /documents/Zwift folder and reinstalling Zwift.
As long as you are a local admin of the computer you should be good to go.
Agree with Paul Allen at this point.
I am assuming you have presented the problem to Zwift support team via an official ticket.
Remove the current Zwift files and get yourself a nice new clean install.
If the problem persists, let us know the specs of your computer inc graphics card, the display and so on.
