Zwift was fine yesterday, opened and ran without issue. Today I’ve had this script error appear when Zwift starts and then when the program runs its impossible to use due to graphics either missing or running slowly and ‘jerky’, not smooth.
Tried reinstalling but nothing is working, can anyone help?
I got the same script error when trying to switch user and login. The error points to a Pinterest javascript which causes IE11 to return an error. But I don’t think it has any impact on the game itself, or the ability to switch user and login.
Same here. I’ve been running zwift for a couple of years with everything stable. The errorhas been ocurring for the past few days (after last update?). Doesnt appeear to affect the game though.
By the way, the javascript file generating the error is a Pinterest js file. I have never opened Pinterest on this computer. No idea why a pinterest script is running from the Zwift loader. Suspicious.
Do anyone else have a solution for this problem? I can’t change the settings in IE because I use Zwift on a managed PC and the system administrator doesnt allow me to do these kind of changes.
I dont understand why Zwift doesnt solve this problem or post any public info since it look like it affects a lot of customers (or have they but I’ve missed it?).
I have admin rights for installation programs so I have no problems to install Zwift.
The prioblem I have is that I get this strange scriptError when I start Zwift on my computer. Frank_Krauthauser wrote a solution for that scriptError, but I cannot use that solution. The reason is that I have a managed PC and I dont have the rights to add new restricted sites in InternetExplorer.
Does anyone else have a solution how to get rid of the scriptError that (I believe) get Zwift to hang?
That script error in the launcher cannot cause the game itself to hang. The launcher is a separate program (zwiftlauncher.exe) to the game (zwift.exe). Just choose to continue to run scripts to log in.
Hi all, yes I confirm that the script error will not cause to hang Zwift, but it is really disappointing to see that zwift requires almost every 2 weeks an update by having the risk that such an error can occure. Script errors occure not the first time. I have automated the startprocess and this error causes to break any automation. However Zwift requires to get paid every month and here I would expect that this issue gets solved esp. when mutiple people have the same issue.
Is here any zwift responsible who could answer about the current status?
Thanks Andreas
Same issue here. 100% clean install of Win10 Build 19042.572 on Nov 4th 2020 on a basement dedicated indoor cycling PC. No browser installed except the ones installed by MS (Edge+IE). I installed the drivers, a password manager, Zwift and PerfPro, but that’s it.
Same issue here.
As I don’t have a smartphone, I connect directly with my PC, ignoring the message, and log on. There doesn’t seem to be too many issues. Just wondering if this makes a difference?
