Hello, new to zwift and i have it hooked up through apple TV but the zwift screen is larger than the screen being displayed on. I have gone into settings to see if i can swap from “full screen” to “windowed” but this option is not there in settings. Any thoughts?
Need to check the aspect ratio/zoom/overscan settings on the TV itself. You want to be on 100%, original or similar.
Thanks Dave
i have checked TV aspect ratio and is set as standard 16:9 original, not zoomed. other channels through apple TV, netflix, movies etc, are all showing correctly. appears to be only zwift that is magnified
any other thoughts i could check?
thanks
You might try what others have in this thread:
Which TV do you have? It sounds like your TV is doing something weird.
