Saving & exit
How do I save a completed ride without exciting the Zwift program ? , Cannot see an option to just save and stay in Zwift.
Same problem, I get kicked out of Zwift before being able to end and save my ride. I am using an IPad.
Not possible (technically) on PC/Mac platform. On iOS & AppleTV it is possible as it takes you back to the main log-in screen instead of fully quitting.
A workaround (which shouldn’t have to be the case to use) is to ride, then when you are getting near done the 1st ride you can create a meet-up for 5 minutes or so from the time (you have to invite 1 person, they don’t need to show up though) and select the world/route you want to do. Then in-game you will see a “join event” button in the bottom right, click it when ready.
This will save your 1st ride to zwift/strava/garmin/etc if you have those connections setup and take you immediately to the next ride without having to close the game.
Thanks for that does seem silly that you have to exit the program, takes my pc another 5 mins to reload the program otherwise
How is this not possible technically on a PC/Mac platform?
The work-around is unreasonable to navigate through a series of steps while still riding to “trick” the system to set up another route to ride.
Closing this thread so we can keep the conversation in one place: Allow Saves Without Exit
Ride On!
