Same problem mine goes all smoothly, then downloads the update then problem starts
Goes from flashing blue to red light andcsticks on deleting 1 of 130 files and something about bootloader
Make sure all other applications that could connect to the trainer is turned off.
If all else fails try another phone.
Hello everyone.
Same problem as @andrew_carr , update blocked on Erasing page 1 of 130.
Tested on iPhone 16 Pro, iPad and Android phone.
Same result.
I can confirm that only the Saris application works when I try to update.
I donāt use any other application that could connect to my H3.
Iām hopelessly stuck on V31.059, unable to install v31.065.
No concrete solution from Saris support.
Except that the motherboard or wifi antenna might be the problemā¦
No problems using the home trainerā¦
A bit disgusted.
Same here saris said wifi antenna
