I am very new to Zwift and trainers.
I purchased a Saris Fluid 2 trainer and received it today.
It came with a Saris speed/cadence sensor which we attached on the non-drive side crank arm as per the instructions.
I downloaded the app on my IPhone and mirrored it to TV.
The Ant+ Dongle is in the USB port on the TV
When opening the Zwift app is asks for Connection options. When I select speed sensor it pairs and then connects to speed and cadence sensor. ? It then says connected.
I see everything on my phone and tv but the avatar is not moving no matter how much Im peddling.
I then tried uninstalling and reinstalling. Connection is there and Bluetooth connection is fine. Still not moving.
Then I disconnected my phone and tried ant+ on laptop. Connected fine but still not moving.
What am I doing wrong? I’m a complete novice. Any advice would be appreciated.
Hi, thanks for reaching out. The sensor that came with the saris fluid 2 is the one I have. It’s called Saris Magnetless Speed or Cadence Sensor. I programmed it as a cadence sensor.
I downloaded the app on the laptop and placed the ant+in the laptop. It pics up the cadence as the numbers are changing but the avatar still does not move .
I also followed that exact video and I am able to connect it as it appears on the video. But what i picked up is that it connects as a speed and cadence sensor.
Having never used Zwift without a cadence sensor what happens to the pedalling animation ? Does it just show a default pedalling action. Also if Zwift can’t detect your at zero cadence does supertuck work ?
