Not with the Stryd in particular but lots of others no longer able to connect devices.
Since last issue, I am no longer able to connect my Zwift Runpod with my android. Was working perfectly fine the day before and battery is new.
Same here, wonāt connect with
either Stryd or my Garmin run pod.
Try switching between run and ride mode on the pairing screen, you might find it connects then.
I just had to update zwift on my android mobile device and after that, runn sensor is not binding anymore.
I do see it on trainerroad and configurez softwareā¦
It is a shame. so not able to log my runs on zwift, one of the reasons why i keep my account open over the summerā¦
Hello all,
Thank you for flagging this up. Iām not seeing evidence that this is widespread, but we should be able to locate a root cause and flag this up to the developers.
For those affected, are you no longer seeing your runspeed sensor in the pairing screen, or is it just otherwise failing to pair?
Rowdy, itās definitely widespread, multiple threads on it across the different headings.
Definitely a BT issue mostly affecting those using mobile devices to connect Zwift.
Thank you @Run.10K.Every.Day. For clarity, weāre seeing roughly the same number of Zwifters pair their Runn/Stryd/Footpod devices to 1.39 as we saw a week ago in 1.34. Iāll keep investigating.
Hello folks,
Iāve merged a couple similar threads and flagged this up at HQ. Weāre tracking reports and investigating changes.
Update. Switching to bike and back fixed speed and cadence, but broke HR, which was the only thing wirking at first. I got my run in, but without HR. I donāt even see HR on the bike pairing screen.
Hi all,
Weāre still looking into this, but it looks like there is a workaround for now:
Please skip the initial Pairing Screen, proceed to the Home Screen, then select the pairing icon on the Home Screen to pair your device.
Sorry for troubles, Colin.
We found the problem. Fix is coming next release
Another (possible) work-around:
Switch sports in the pairing screen several times, and then leave it on āRunā.
That may fix it.
Hi, I just want to say that I still have the problem. Been uninstalling and installing the Zwift app every time I want to run.
Have you tried both the workarounds? They work for everybody so far.
Didnāt know about the other one, it might work. Iāll try it next time. Thought I had tried the switching before but didnāt work.
Want to say that the switching between cycling and running indeed worked.
Hey all - this issue has been fixed in game version 1.41, which is rolling out over the next couple of days across all OS platforms. Please update when it is available to you.
