Running a back up device
I’ve got a long (up to 40 hours) fundraising ride planned on Zwift this Friday (NZ time). I usually just run the app via my laptop but once or twice on longer rides the laptop or app has fallen over and I’ve lost the ride data completely. To avoid this happening on Friday I was keen to simultaneously record the ride on the Zwift app on my iPhone. I’ve been testing that and the connection appears to disconnect from my iPhone. So that option doesn’t look viable. Are there any suggestions on how I can safeguard from losing the data mid ride please?
You definitely should not run the game on two devices at the same time. That may cause the ride to be lost, and other problems. Make sure you kill the app on your phone or delete it.
If you want to talk about the crashing problem please share details about the device you’re running it on.
If what you care about most is just the data (not in Zwift, but a fit file you can stick on Strava) you could record it on a cycling computer while using Zwift. You would not get matching speed or distance compared to Zwift, but time, power, cadence, and HR would be about the same.
Cheers Paul. I had the same thought and tried it out tonight. That’ll be the best fall back option I think. The laptop is getting on a bit and I think it crashed due to that. Murphy’s law it’ll fall over this time - especially as it will be recording for up to 40 hours.
If you tell me the specs for the laptop or the model ID (usually on the bottom) I might have suggestions for you. Alternately, a screenshot from the System Information app in Windows would be enough.
You could connect to MyWhoosh for free as a backup on the second device
