Resistance Super Hard at Start of Workout
3 posts were merged into an existing topic: Trainer Difficulty setting reverts to maximum [October 2022]
My PC is not within reach in my setup (it’s connected to a TV screen)…
So I can’t be peddaling when I start the training.
I think it is absurd I need to do an all-out sprint to start training…!?
Trainer is an Elite Suito T.
Does Zwift plan to solve this weird issue?
Regards,
Casper
Given the PC is not handy, if you use Companion App you could hit the Pause button or turn ERG off (both on the CA workout screen) which should enable you to start spinning then just switch whichever one off.
Do you use the companion app? If so, pause the workout immediately after starting the ride on the PC, then get on the bike and start pedalling, then unpause the workout.
Bumping this thread because I just did a workout today where I encountered this … like I’ve encountered it before.
I don’t know if this has been made clear, but in response to Gerrie, it is not an erg mode issue. Zwift didn’t used to lock the trainer up at the start of the workout before the initial complaint. Also, Wahoo SYSTM didn’t do this, someone else mentioned that TrainerRoad doesn’t do this.
Now, I have just enough strength to turn the cranks to unlock the death spiral. Great. Or I can select a course, then pedal gently, then select a workout. But seriously, I should be able to select a workout from the starting menus, then select a world, and then be able to pedal once the ride starts. This hasn’t been fixed, and I would like to see it fixed.
if you do custom workouts one workaround is to add 15 seconds or so of free ride at the very start so you can get pedalling before the erg sections
Good point. However, we pay Zwift $15 a month and they got all sorts of venture capital investment. I hope they don’t think that riders can just work around this one way or another, it’s not a big deal.
I never experienced this behavior (Kickr Core, ATV). Are we really sure that this is a Zwift problem and not a trainer problem? Adjusting resistance is on the trainer side, Zwift is only sending the target.
I use Zwift on my Macbook.
That said, as I said before, this behavior was something that presented after a Zwift client update a couple years ago. It hasn’t fundamentally been fixed. It’s not present when I try the free workouts in Wahoo SYSTM.
I have the exact same issue when using zwift with my direto XR. The only workaround is to choose a course, do a custom workout, start in free ride, then select a different workout. I did not have this issue last winter btw. It’s silly and I am losing patience.
I have the exact same setup and experience the exact same issue. I just did a firmware update. Did you resolve your issue?
If you check Elite’s forums you’ll find that this issue does come up from time to time and can often be cured by taking off the cover of the trainer and re-greasing a particular part.
Elite support will help you too - have you raised a ticket with them?
If that’s what’s going on, here’s the previous discussion of it
I have found a youtube video for this and have had a look. Yes the screw was full of old sticky grease. I have degreased it and applied some Shimano premium grease. Hope that sorts it. If not I will contact elite support. Cheers!
Thanks. I have done that now. Fingers crossed that this will sort the issue.
I’ve not managed to fix it. I can work around it most of the time (make sure I’m pedalling as I start the workout for example) but its not gone away. As before, its only an issue when doing a Workout. The trainer is a few years old now, I’ll just be sure not to get one from Elite next time.
Did you take a look at the motor screw and/or talk with Elite support?
Have you applied the recent firmware update which included a feature to make it easier to start workouts?
https://www.elite-it.com/en/news/new-features-for-your-direto-xr-and-suito-trainers
Hi, I I have read your problem and I think I have the same and I read the solution you’ve been offered about starting pedaling while the game is loading does it really work?
