Repack Ridge
When finishing repack ridge on the Windows platform the rider Avatar does not get back on the road. It ends up going to the right of the road and continuing off trail. Also at the end of repack ridge as the Avatar is going down towards the finish line the Avatar ends up under the road looking up at it for just a bit.
Sounds similar to this - Did I found a bug? Flying over watopia after Repack Ridge
@Kent_Lee1
Thanks for bringing this to our attention! I checked with the team and confirmed it’s a known issue and the developers are working on it.
This is still broken, plus, the steering with the companion app doesn’t work. for months now !
I encountered this issue today and yesterday as well. It is still broken.
Hi @Matthew_Christian
I checked with the team and confirmed that the issue is still assigned to the Zwift dev team and that they’re working on a fix.
I’ve again raised this up and asked that they escalate the issue so as to get it fixed as soon as possible. Thanks!
Hi
Having possibly the same type issue. When I complete Repack Ridge, I cant continue to the road to do again. Zwift steering goes away but I can continue to pedal but it doesnt track the road. I go thru weeds and whatever is in the way. I see no controls to resume at all so I have to just quit the ride. It used to work but hasnt in the last few weeks. Not sure what is going on. I am using android tablet with my phone using companion. Not sure if I am missing something…ugh
Hi @Eric_Casteel
Yes, it sounds like the same issue. If your avatar is basically flying off the entire route, then it’s the same issue.
I know this one seems like it’s taken a while for Zwift’s developers to fix, but I know it’s on their radar and that they’re working on it. We can expect an eventual fix at some point, hopefully sooner rather than later. Thanks for sharing!
Thanx Steven. Hopefully its fixed soon.
