I have a power tap SL + and when I go to Pair it with zwift, I have the option to pair the hub or the handlebar computer that came with the hub. Is there a benefit to Pairing the hub or should I pair it to the handlebar computer? I plan on using the handlebar computer to zero the torque.
What kind of hardware are you running Zwift on Chris?
For quickest reaction times I would pair the hub and allow Zwift to act as your data display.
Paul,
I’m running a Dell XPS 18 all-in-one touchscreen.
1.9GHz, i3
4GB ram
64 bit
It’s a bit doggy but works.
Thanks, Chris
You need to pair the hub, I don’t think the computer will bridge the signal or even connect to Zwift. The hub is what is broadcasting the watts.
Make sure your PC meets the minimum requirements: https://support.zwift.com/hc/en-us/articles/203193315-What-are-the-minimum-computer-requirements-for-Zwift-
Yes Chris
Set up Zwift to read the hub and your other sensors directly.
Ride On!
