Hi there,
I’m using Zwift on two configurations, 9900k + RTX 4060 Ti, and 265K + RTX 5070 Ti, and have experienced very bad freezes of all computer (from 5 to 30 seconds), without explaination.
I’m using a windowed display, Zwift resolution on 4K, on my TV (Sony 4K / 60 Hz), in order to have something else (browsing, video, netFlix, whatever) in another corner of the screen.
To get what’s going on, I’ve run task manager on a third corner of the screen. So here what’s happening while Zwifting :
- GPU is cruising at 25% load…
- …and around the 40 minutes mark, the GPU load increases to full
- To avoid freezing, I’m downgrading Zwift parameters to 1080p, GPU load decreases to around 45%
- This “overload period” lasts around 10 minutes, then GPU load decreases to well under 20%, allowing me to bring back 4K in Zwift parameters…for the next 40-ish minutes
I’ve done a 2h40 (metric) fondo this morning, so the scheme happened exactly three times.
Nothing special on Zwift (crowding, textures, power on Home Trainer - TacX Neo2T, etc…), CPU is cruising, RAM as well (~ 12 gb used for respectively 32 and 48 gb installed), VRam peaks at 6.6 gb, absolutely clean install (Windows 11 25H2…but was the same on 24H2, DDU before each NVidia driver update), obviously latest NVidia drivers, no network (ethernet) issues (I tested it during each 10 minutes overload periods), I’ve tried to kill my other tasks during the 10 minutes overload period, without any impact on GPU load, and I didn’t touch any of the parameters in NVidia control panel, which are applying VSync on default (no problem to me as my TV is 60 Hz)…so it’s not the GPU going crazy producing lots of FPS. And finally, nothing special on log through Zwiftalizer, looking at a “frozen” log or at a “keep it 1080p for 10 minutes” log.
Hey, Zwift, what’s going on ? ![]()
Thanks !
