Hello. I have installed zwift on my mac. I have wahoo sensors whic support ant+ and bluetotth smart. But there is problem i cant connect them to zwift app.
CONNECTION WITH APP ON THE PHOE IS WITHOUT ANY PROBLEM. BUT CONnect to my mac app it doesnt connect.
Maybe someone can help me>
Hello @Sergejs_Tutovs
I had same problem with my MacBook.
You need buy ant+ usb dongle (any cheap you can get) and then sensors will connect
ANT+
If you want to use ANT+, you need to buy an ANT+ dongle. I use and recommend the Garmin USB ANT+ dongle. I also recommend a USB extension cable to put the dongle closer to the trainer and sensors.
Bluetooth
- What version of OS X are you running? Need at least 10.9
- Does your MacBook hardware support Bluetooth 4.0?
- Click the Apple on the top left corner.
- Select About This Mac .
- Click on the More Info… button.
- Click on the System Report… button.
- Select Bluetooth from the sidebar on the left, underneath “Hardware.”
- Scan down the list of information until you find “LMP Version.”
If you have a Mac with Bluetooth 4.0, the LMP Version will say 0x6
- You need to be sure that nothing else is connected/paired to your sensors via Bluetooth when pairing with Zwift. Otherwise, Zwift will not see the sensor.
