I’ve just started and have set up my elite Turbo Muin, but when I link it to Zwift, it says I’m only doing 5 watts. Im using a Misuro B+ and have selected power sensor on Zwift set up. Any ideas?
Can you connect and calibrate your trainer with the Elite app? When you connect to Zwift do you select “Power Source” and does your correct model of trainer show in the list?
Thanks Bob. Turns out there was an issue with the battery in the sensor. I’ve replaced it and it is now working. Thanks for your help
Your battery had no power not you ![]()
