Hey there,
I recently started using an Elite Turbo Muin with Misurino B+ cadence+power sensor.
When I test it with Elite app I have a reasonable output watts (same as I have on the road), but when in Zwift I barely have the 50%.
anyone experienced the same?
thanks in advance
Hi @Mattia_Panozzo, welcome to the forums!
I’m Fernanda from Zwift.
This caught my attention and I couldn’t miss the chance to help you! The Misurino B+ cadence+power sensor needs to be set to 12 blinks for the Turbo Muin Trainer (you can find this on the table within the instructions of the sensor).
Could you please confirm to us if this is correctly selected on your device configuration?
On the other hand, remember to wake up the device (pedaling) before pairing the power sensor, based on other Zwifter’s experience, the pairing of the sensor can be different in Zwift, I would like you to check this forum thread with the correct steps.
keep us posted!
Hi @FernandaA , thanks for the quick answer.
The Misurino is properly setted, as with the Elite app I can see the right values.
I would say the issue is somewhere else: the cadence is right, but the power is about half of the expected one
Thanks!
