Zwift support answered with the usual Zwift non-sense: half of the message from the support is about “…we are sorry about your bla…bla..blaa”, the other half they just repeated with the suggestions that I’ve already done previously.
Very helpful, thanks guys!
Zwift was fully removed once again, registry and all the leftovers etc.
So, noticed some issue with the Win 11 pro Update:
Target Update: KB5074109 (Windows 11 Security Update, released Jan 13, 2026)
Windows Version: Windows 11 24H2 (OS Build 26100.7462).
And I had an assumption, that my issue with Zwift might be from that update that failed to update multiple times.
ran dism /online /cleanup-image /restorehealth, which successfully repaired the corrupted Windows image. SFC Scannow: ran sfc /scannow, which identified and replaced corrupted system files that were preventing the OS from functioning normally.
Fresh install of Zwift once again (for the fourth time).
Still same issue. No light beam.
Logs reviewed, still same issue.
Inside the log: [GFX]: GFX_Tier 0
So updated the ultra.txt file with the following, tried to force gGFX_Tier=3:
set gGFX_Tier=3
res 3840x2160(0x)
sres 4096x4096
set gSSAO=1
set gFXAA=1
set gSunRays=1
set gHeadlight=1
set gFoliagePercent=2.0
set gSimpleReflections=0
set gLODBias=0
set gShowFPS=1
But still same issue.
In addition inside the logs:
log still shows critical errors regarding missing game files:
ERROR: Could not load wad file: assets/gearing/gearing.wad
ERROR: Sky::Load(): Watopia not found
loading shader GaussianBlur... failed!
Tier 0 Rejection: attempt to force the graphics tier with set gGFX_Tier=3 was rejected by the game with the error: Error: Variable "ggfx_tier" not found!
Any ideas?
