Now power data in fit file?
Hello I just did a half marathon run in zwift. I used Runcline. Finished the run, powercenter says there is no power data in the fit file. Anyone else have this issue?
Having the same issue using Runcline. If I use Stryd pod directly with Zwift power data is saved. Using Runcline to get incline data the fit file does not contain power data.
RunCline can pass power correctly when Zwift runs on an iOS device (tablet or phone) but not on other Zwift platforms. The issue is on Zwift’s side where power is ignored when incline is present and the BT FTMS Service is used. Go figure! Only workaround is to use the FIT file from RunCline and upload the file afterward.
