Hello. I’m trying to setup Novo Force 8 and Misuro B+ to Zwift application using bluetooth only (don’t have ANT+ adapter). I got this to work however the speed and WATs I receive are both far from true. To give an example - I feel like riding 15-20 kph but Zwift shows 35 kph and like 400 WATs. Doesn’t matter if I pair Misuro B+ to pc directly or connecting to android application and then pc, results are kinda the same. Do I need to specific exact type of trainer I use? If so, where to do that in Zwift? Misuro B+ is set at 12 blinks as it should and other app (myETraining) gives pretty much accurate results. Best regards
Hello, I have set to 7 blinks for the Novo Force and I set the power on 3…don’t know if it makes sense…
