Hi
My avatar is not moving in zwift everything is paired , I’ve tried this on Bluetooth on an iPad and ant plus on a laptop with the same result .The same thing happens on other cycling apps . I’m on a wahoo kicker snap . It worked fine yesterday then today it started acting erratically telling me I was putting out 1200 watts which is impossible then slowing to 3mph on a flat course which also wouldn’t happen before stopping altogether.im at a loss of what to do
Sounds like you should contact Wahoo support. Have you tried a spindown calibration with the wahoo app, and firmware updates?
Also try a Factory Spindown if the normal spindown does not work.
Avatar not moving at all since new update yesterday. Everything connected. Firmware updated. No VPN interference. Tried phone and iPad with app downloaded again fresh. Membership up to date. Any suggestions?
You’ll need to give far more detail, trainer type, how connected, Zwift device etc…
Zwift hub one. Bluetooth. iPad with zwift app. APP updated yesterday. Companion shows all firmware up to date. Zwift app connects to everything normally via Bluetooth. When pedaling in a route no power on cadence recorded. Avatar stationary. Trek Domaine SLR.
