Hi @Maureen_Mahoney and welcome to Zwift. Lots of things can interfere with bluetooth connections. If you search the forums you will find a lot of threads on this topic with lots of possible solutions.
When did this start exactly, it sounds like things were working fine until recently? Can you check to make sure you are on the latest version of Zwift, there was an update recently that refreshed the Richmond course. IOS devices can sometimes have auto update turned off so you would have to manually update them.
Thanks for the reply. Yes, you are correct- our set-up has been working fine for over a year. The number of active bluetooth devices in the room wasn’t new either when our avatars stopped moving last week. I paused my ride for less than a minute to shed a layer and that was it, she stopped moving. When my husband tried to ride the next day, his avatar wouldn’t move at all.
We have reviewed several threads but haven’t found a solution or suggestion that we hadn’t already tried. That’s when I decided to start my own thread. We’ll keep looking. Hopefully, we figure it out soon. There’s still a lot of winter left…
On occasion, my avatar quits pedaling but keeps moving along the route. I figure he’s riding a class 2 ebike. I’m still laying down the Watts and those and my cadence continues to display properly.
Hi @Maureen_Mahoney sorry for the lag over the US holiday weekend!
First, thank you for outlining the things going on at your end - that helps us troubleshoot for sure!
I’m comparing what may have changed from your last successful session on Feb 12 and the problems you had on Feb 13. No obvious changes are sticking out on the server logs.
EDIT: I’m showing you’re running a slightly older version of the game app: v1.0.45410. Would you update to v1.0.45663? My apologies - 45663 is our latest version for Android
When you run it for the first time, you should be prompted to allow the app permissions to access folders on the iphone / ATV. Say yes - these permissions are what allow the app to access the Bluetooth radio hardware.
Would you loop back and let us know if these helped?
