I am connecting a win10 PC via ANT+. I have a NEO.
All was working just fine.
Now it is connecting and losing signal, showing no signal on pairing screen.
I understand there is an issue with win10 and BT connections but does this apply.
I have tried different ANT+ dongles, connecting to garmin edge, all fine. It is the connection via ANT+ that is issue.
Many thanks
I have the same issue with my ANT+ connection on Win10 on a Bkool Smart go. The connection drops out between the trainer + pc every 5 minutes.
Also, when connected, the resistance of the trainer fluctuates sporadically and drastically, even in training mode.
It started three days ago after a Windows update. Can anyone help?
Thanks!
This is just a shot in the dark, but did you try to disable Bluetooth completely on your Windows pc.
I have this same issue too!! We are discussing on another thread, but I AM ON A WAHOO KICKR … this is a Zwift problem or a Windows problem and it is not to do with the win10 update … This is something else …
I do not have bluetooth on the PC.
I was wondering if its to do with Garmin Connect or Express.
How do you see if running in background and disable ?
I would delete this on my Zwift PC. It is known to interfere.
Or change the settings in Garmin Express so it doesn’t launch automatically on Windows start-up
