Connection Problems with Tacx Neo Trainer Operating system Win 10
since some day I’ve connection problems with my Tacx Neo Trainer via ANT+, today I’ve used Tacx Trainersoftware and everything works fine. Is this a known issue and what I have to do to get a working connection?
Thanks for information an best regards
Frank Lengers
Zwift uses more data so it is not an apples-to-apples comparison.
Are you using a USB extension cable to get the ANT+ dongle as close to the trainer as possible?
Hi Paul, thanks for answering, yes I do. I am using this setup since 1,5 months and I never had any problems
Greetings
Frank
Trying going through this KB to see if it can help resolve the issue: https://support.zwift.com/hc/en-us/articles/204186849-My-ANT-signal-is-dropping?section=201145295
Hi Paul, many thanks for this helpful Link. I’ve connected to Zwift again and Zwift has found my device immediately, a short test ride hasn’t caused any trouble. I think my bluetooth mouse has caused the trouble, I’ve placed it a few centimeters away and everything has worked as it should be.
Gerat Support!
Many Thanks and Greetings from Germany
Frank
One supplement, it would be also nice if would BLE make working with Windows 10, it would make Things much easier.
Frank
Hi Frank,
It looks like Paul already steered you to our KB support article for eliminating signal interference.
If you continue to have the same problems, please submit a support ticket and one of our Zwift support team members will be happy to further assist you.
