Hello!!
I have finished the Royal Pump 8 Room ride but didn’t get any badge update on that ride. Has anyone have the same experience or have I missed somerhing maybe?
/Johan
Hello!!
/Johan
Welcome!
Similar complaints have been brought up a numerous times here.
It seems the issue is not that much of Zwift’s, but possibly a user issue (sorry…): Are you sure you completed the route? Sometimes the spawning point is not the start of the route. Also, any course change mid-ride (turning), will nullify the achievement badge. Have you seen the badge banner at the end of that ride?
Can you upload a screen capture of the route?
Thanks Ben yes I have seen the ride Completed in the end, that’s why I’m confused.
When I look in the badgelist it’s not updated
Try turning your device off and on again.
I have turned the device off, but it’s still the same
My belief is at some point the zwift server will update and your app will show you have the badge. I thought the force quitting of the app or the restart of device would do it.
Ok, thank you for the answer, just have to wait and see then.
@Johan_Halin do you use more than one device for Zwift? I have seen this happen when you have open sessions on other devices like an iPhone or something, once that is force closed it might fix the issue you are having.
Aha, thanx Mike maybe that’s the problem, Should I log out And in on the Zwift App maybe then on the IPhone?
