New to Zwift, pc always crashing
Hi there, I am new to Zwift and my PC always crashes. I even put the resolution to 720p. It only worked 1 time without crashing. I just realized that in images/zwift folder, there are screenshots of my rides even though I disabled screenshots.
I just installed a new version of windows 11 and I installed the latest up to date AMD drivers after using DDU.
In the log file, it says this:
[13:39:16] [WARN] Auxiliary Controller failed to shut down tcp socket: ‘Une requ te d envoi ou de r ception de donn es n a pas t autoris e car le socket n est pas connect et (lors de l envoi sur un socket datagramme en utilisant un appel sendto) aucune adresse n a t fournie.’ (10057)
[13:39:16] [INFO] Auxiliary Controller failed to connect to socket: ‘L op ration d entr e/sortie a t abandonn e en raison de l arr t d un thread ou la demande d une application.’ (995)
[13:39:20] FPS 138.89, 287165, 11370, -35828
[13:39:27] [INFO] Auxiliary Controller attempting to connect to phone at: 192.168.18.5:21588 (secure)
[13:39:28] INFO LEVEL: [ZwiftHardware] Set ERG (280w)
[13:39:28] FPS 126.58, 286698, 11469, -37669
[13:39:32] [WARN] Auxiliary Controller failed to shut down tcp socket: ‘Une requ te d envoi ou de r ception de donn es n a pas t autoris e car le socket n est pas connect et (lors de l envoi sur un socket datagramme en utilisant un appel sendto) aucune adresse n a t fournie.’ (10057)
[13:39:32] [INFO] Auxiliary Controller failed to connect to socket: ‘L op ration d entr e/sortie a t abandonn e en raison de l arr t d un thread ou la demande d une application.’ (995)
[13:39:36] FPS 131.00, 285980, 11606, -40404
[13:39:37] INFO LEVEL: [Route] In route intersection - Normal
[13:39:40] [Route] Hit checkpoint 32 out of 50 on route: " Classique"
[13:39:43] [INFO] Auxiliary Controller attempting to connect to phone at: 192.168.18.5:21588 (secure)
[13:39:44] FPS 132.16, 284792, 11782, -44218
[13:39:48] [WARN] Auxiliary Controller failed to shut down tcp socket: ‘Une requ te d envoi ou de r ception de donn es n a pas t autoris e car le socket n est pas connect et (lors de l envoi sur un socket datagramme en utilisant un appel sendto) aucune adresse n a t fournie.’ (10057)
[13:39:48] [INFO] Auxiliary Controller failed to connect to socket: ‘L op ration d entr e/sortie a t abandonn e en raison de l arr t d un thread ou la demande d une application.’ (995)
[13:39:50] [INFO] World clock offset updated from +393678537ms to +393678536ms (-1ms)
[13:39:52] FPS 126.58, 283305, 11824, -48923
Thanks in advance for your help.
The Zwift app crashes, or the PC crashes? If the PC crashes then you need to investigate what’s wrong with the PC.
The computer screen becomes one colour and I need to reboot but since I play full window mode, I can’t know if it’s zwift or the pc…
Oh look… another AMD user :upside_down_face:
They have an Intel CPU so aren’t using AMD integrated graphics, so this doesn’t seem to be the same problem.
I will try using my igpu (intel) only and see if the problem occurs.
Hi @Phil_CanadaQc2025,
This is Haziel, part of the Zwift Support, many times crashes and freezes can be caused by out-of-date graphics drivers.
Could you please confirm that your device is running the latest Operating System, Graphics Drivers, and Zwift App version?
For more info on checking this information, check out this article.
After checking the logs, I noticed that you might need to update your graphics drivers.
If the issue persists or you have any other questions, please feel free to contact us.
Hi @Haziel_P ,
I have the latest version of windows 11 updated through Windows update. I have Zwiftapp’s latest version. To make sure, I uninstalled it and redownloaded and installed again.
I also have the latest amd drivers from my Rx580 offered on the website.
So this happened today:
  1. Radeon Rx580, 720p, windows defender off, one drive uninstalled : crashed on the start menu while I was switching clothes
  2. Radeon Rx580, 720p, windows defender off, one drive uninstalled: crashed at 3km off the end of Makuri Islands
When it crash, the monitor becomes gray and there is nothing I can do but to reboot the pc.
The other day, I used my igpu (skylake) and it ran without issues.
UPDATE:
I searched the web and found out a lot owners of my AMD Radeon RX 580 8GB MSI ARMOR OC suffered from wrong “base” values and it would make the card crash. As suggested on forums, I underclocked the base value by GPU Tuning by 8% and I experimented no crash for a hour long training program.
I will be riding for 1h30-2h today in 1440p and report back if there is any crashes. Fingers crossed.
