I did 3 activities on 19/12/24 I end the ride and saved as I normally do however it did not show of any of platform like Strava, Garmin connect, or zwif companion, can you please give some information how I can overcome this issue.
Were the rides each longer than 2km?
same problem here but only with strava
Zwift Comp. and Garmin works fine.
no uploads 18/19/20 december
yes, 20,43 and 21km
On what device are you running Zwift?
on two Windows PCs
one at home and one in my holiday apartment
and I also have Zwift on the iPhone in case of emergency ![]()
I also always have the Companion app active when I use Zwift.
I have now verified the connection and will report back tomorrow whether the uploads work automatically again
Update: After manually disconnecting in Strava and reconnecting on Zwift Website, the uploads work again. Whatever it was…it’s gone
Hi guys! Welcome to the forums! this is Monica from Zwift. I understand how important it is for you to upload the activities to Zwift and Strava. I recommend checking your Strava account for alerts or updates. If you want to reconnect your Strava account to Zwift, you can follow the steps outlined in this article. It’s a simple process that should help restore the connection.
If you need to upload your activities manually while we sort this out, you can download the fit file directly from your Zwift account here and then upload it to Strava here. This way, you can keep your training records up to date.
You can upload them manually by downloading your tuning files with the following steps from the activity feed:
After you have logged in to Zwift.com, complete these steps:
- Go to zwift.com/feed.
- Select Just me.
- Locate and select the activity you want to download.
- Select the gear icon
- Select Download Fit File.
To check if the upload was successful, I recommend that you complete a ride, save it, and then check to see if it has downloaded successfully to Strava.
Also, make sure the activities are recorded with the correct date.
Please let us know if the issue persists and if you have any other questions or concerns.
Thank you for your patience and cooperation!
