Moofit Speed
HI,
I am using a Moofit speed and cadence sensor…newbie…
I have connected them up to the zwift APP. Cadence is picking up RPM Fine, speed however is stuck on Zero. Any ideas? I have it set up on my rear wheel axle, using BTwin 100 trainer?
Thanks.
Ross
Need more details on how you’re connecting them and what devices you are using for the app.
Looks like others have had an issue with this type of sensor. It could be a case of buy cheap buy twice I’m afraid.
What is the recommended manufacturer/brand of sensors (speed and cadence) that are fully compatible with the ZWIFT app? Didn’t get the MOOFIT speed sensor to work and looking for a “better” sensor pair.
Hi @go4java, welcome to the forums!
I’ve used the Wahoo Blue SC in the past, they have other styles too that go on the rear hub that work just as well. I would stick to a name brand that you know and trust.
I’m using these on an indoor bike, they are working fine – I’d just double check to make sure the S- and C- are connected correctly with speed and cadence. I’m just trying to figure how to calibrate the resistance to make it more/as close to outdoor riding
I ran in to the same issue, and the fix is to manually enter the wheel circumference in the speed sensor’s settings in any app or ANT+/BLE bike computer that you are using.
I’m pretty sure you have to get two per the video on Amazon makes it look? I was waiting to figure this out because I was took g to buy one , then I watched the video and saw that they turned the button on to turn cadence on and then showed cadence information, and then they go back to an entirely new scene with a new sensor and turn on the speed and talk about the speed info so that’s why it made me think you need two sensors. Which on Amazon is either $14 for one or $28 for two but kind of just a pain. I have only got about six comments down not sure if there is a fix by the time I hit send on this or not and start reading the rest of them though ha ha
