Hi is anyone else missing the results from last evening’s volcano climb race .
I can see the results on zwift power but nothing on my companion app.
Is it possible that I didn’t save it yet it still shows on zwift power ?
If you didn’t save your activity the results still make it to ZwiftPower but a fit file is not uploaded to ZP. You will notice on your ZP race results you have a green flash in the results, generally a sign you either didn’t save your activity or you saved it privately. Had you saved it privately you would have been able to see your activity report and within it the results.
As you suggest, most likely a saving of the activity issue.
Thanks Ian … strange I didn’t save it given I’ve done the procedure 100,s of times . Ah well cheers
