Try my solution, worked for me…
Samsung galaxy tab A
Android 10
Tax booster
Garmon speed sensor
No power meter
ANT+
Tablets ANT+/Bluetooth with ANT+ USB stick
Thx for the workaround Martin!
Same issue with power being off the charts…was working fine before the update.
Running on Win10 laptop
Tacx blue matic
Speed and cadence sensors as supplied with the trainer
Ant+
Tried suggestion to switch over to elite nova…and much more closer to power before the update. Thanks Martin
Same issue.
Running on a Mac.
Tacx booster turbo.
Garmin, HR, speed and cadence sensors all connected via Bluetooth.
It’s not exact, but close enough to keep Zwifting…
Same issue here, massive power and speed increase today after update. my set up below ,
Window 10
Tacx blue matic
cadence/speed sensor Polar
no power meter
connect via built in bluetooth
i’ll try the fix suggested in the feed tomorrow with hope it will work
Same issue, power off the chart, cadence appears to be ok.
- Windows 10
- Tacx Blue Matic
- Tacx speed & cadence sensor
- Bluetooth via the companion android app
Tried the Elite nova force as others suggested but for me this is this is overestimating power compared with my usual Blue Matic settting.
Is there a way to delete the badges which I’ve undeservedly been awarded?
Hope for a fix soon
It does give you the possibility to get a slightly higher w/kg, but doesn’t seem to affect speed much, so distance over time is not far out…that’s what I found on 2 X 15 mile trips…
Swap tacx trainer to elite nova force, should work…
For anyone using a Tacx Boost, Tacx Booster, Tacx Blue Matic, or Tacx Blue Motion:
I dug into the defined power curves and found what seems to be fairly close matches:
- Choose Jetblack M5 Mag Pro instead of Tacx Boost
- Choose Tacx Blue Twist instead of Tacx Booster
- Choose Jetblack M5 Mag Pro instead of Tacx Blue Matic
- Choose Minoura MagRide-60 instead Tacx Blue Motion
Edit: This is explained in a bit more detail in an article at ZwiftHacks.
Cool, will try that. Elite nova force seemed an ok option, but I will try the jet-black as you suggest, as you clearly have a more technical solution than my trial and error find !
Fantastic work!
Hapenned after latest u[grade or around that time. Same issue with Tacx Blue Matic, wahoo sensors, Garmin ant+, blew away my FTP yesterday. Had to slow ride for rest of ride. Hope they fix this.
Same issue.
Windows 10
Tacx Blue Matic
Garmin Speed & Cadence Sensors 2
Bluetooth connected directly to computer (not via Companion app)
Same here, using a Tack Blue Motion with Garmin Speed Sensor.
I have the same problem here:
Windows 10
Tacx Booster
Garmin speed sensor
no power meter
ANT+
Thanks in advance
good day. I have a problem with zwift. two days ago it was salty and not Yesterday.
I have an elite realaxiom 2015, connected to the application via cables./ I have a cadence, a control unit connected via cables to the trainer/I use NTB. a Yesterday 18.3 I can’t pair (find) a simulator with an application on any ntb all day. Why?
I tried to connect the trainer to 2 ntb, two different operating systems. and it doesn’t work. i use windows. I have been using the trainer for several years.
Still not fixed since Wednesday morning, same problem again…
Mac os
Tacx Blue Matic
Bluetooth connected directly to computer, not using Companion app
Really frustrating as tried some of the other fixes likes picking a different setup and still didn’t work. I’m either ridiculously fast or dead slow
I am on the same set up Booster with Cadence and Speed sensors and HRM from being able to race at 4.2w/Kg I can now put out 650W at a HRM of 105 in a 21t cog some 9w/Kg. Makes the game completely unusable.
