Hi folks, I’ve been having an issue that only started recently. I have an Elite Suito trainer and I use the Zwift app on my iPhone XR. When I connect to Zwift and start riding the power readings are very low for the first 2-3 minutes. Usually around 40-50 watts. After 2-3 minutes it will then correct and go up to 150-200 watts and everything is fine for the rest of the ride. I’ve tried upgrading the firmware for the trainer as well as calibrating it on multiple occasions, but no luck. I can also correct the problem by starting to ride then ending the existing the Zwift ride and starting a new ride. Has anyone else encountered this issue?
Thanks.
