After updating the Zwift app (Game Update on October 22) on my macbook pro, I decided to start a training. When I opened the Zwift Companion app, the map was still loading at the intro.
Both my Zwift and Zwift Companion app are on the same Network and I even made sure that my Iphone is on Airplane Mode to stop any interference.
I also followed all the steps from the link provided by Zwift Support - Link: Issues with Zwift Companion and still nothing.
- Deleting Zwift Companion app and reinstalling.
- Logging in / Logging out Zwift account
- Shutting Down Router and Logging back in.
Before the update, everything was working fine. I’m wondering if I’m missing anything or if any of you had similar issues to this one.
Thanks all for your help,
Try to restart you modem and wifi router
Thanks Gerrie for the info. Will give it a try.
I had a similar issue this weekend where the map and other riders wouldn’t update on the companion app. I logged out, closed the app, then restarted the app and logged back in. That solved the problem for me. (I’m running Zwift on iPad Pro, Companion app on iPhone 11 fwiw)
Same here! Especially when trying to connect to the Sterzo Smart using the companion apps BT bridge. Only occurred directly after the latest update
Same here with issues. Frustrated
You need to share all the details about your device running Companion, and your device running Zwift if it’s not connecting. Also check if there is a map icon at the bottom of the Companion screen. If you see that then it’s working and you need to tap on it. I think they also removed the ability to see the map when you’re in a workout so test everything when you’re in a free ride.
Not just IN a workout - even AFTER a workout finishes, you cannot switch to a map screen.
At least that’s the way it was the last workout I did a couple of days ago.
