Ooooh, ok that makes sense - thanks!
Great, so I will select the ANT+ option for my next ride, which won’t be until tomorrow, but I’ll keep you all posted!
My friends, hello and good afternoon to you all! I have an issue with a delay in communication between my trainer and Zwift. You see, when I get to hills, the resistance does not change until halfway up a steep one, and not at all on small ones!
I am using the Kickr ROLLR with a Garmin XC-100 power meter and a Garmin Edge 530 cycling computer.
Does anyone have any great tips or advice? Thanks
Very best regards,
DJP
Same issue as you have discussed here?
Why are you using the Edge? There is a possibility that it is interfering with the Zwift-Kickr interface.
Hello, yes same issue, thanks! I am using the Edge to record parts of my ride not recorded by Zwift (Kjs for instance), but you think that may be the issue? I suppose I could try it without it if you think it will make a difference!
Any other comments are still welcome
Thanks all! And very best regards,
DJP
kJs are reported in Garmin Connect if you upload from Zwift to there.
I’m just suggesting it as a possibility. I’d aways simplify the configuration if at all possible to eliminate any crosstalk.
Oooh, really, I had no idea, thanks for the tip! And yes, I do appreciate your take on the Edge computer; I’m going for a ride when I finish here at work and will give it a go!
Thanks again all! And very best regards,
DJP
Its all in his other thread. No point duplucating here.
Thanks @Dean for pointing this out.
I merged the threads.
