Ipad activities upload and sync
Hello,
Did someone experienced issue uploading activities from IPad (M2 2022)? Even with good network connection, with no image / video… I cannot save the activities. They appear has “done” in the training plan but are not in the “feed” section.
Not even talking about sync with Garmin and Strava that does not work either.
Thanks for your help,
Kind regards,
JM
Have you logged in to Zwift on multiple devices? If so, you may not have logged out of one of the sessions, causing a mismatch between logins and logouts. It is generally suggested that you only install the Zwift app on one device, and that you logout after each session. And if you are using an iOS device (iPhone, iPad), it is good to force-quit after each session.
I think the other devices were not connected but I will uninstall the app on all others and try again.
Many thanks Nigel!
