@brumohr
Thanks for taking time to fill in more details!
Everyone else: is an Apple Watch a factor in your setup?
@brumohr
Hello.
Same issue as others described: map loads and then disappears. Today CA worked on iPhone but not on iPad or iPad Air. iPad was V15 so I updated to V15.1 - still didnāt work. No issues yesterday.
I am running Windows 10 with an Nvidia GPU card.
I have also seen āblankā activities when scrolling through my co-Zwiftersā activities on CA for last couple of days.
Maggie
No Apple Watch
No Apple Watch. Companion app works with Apple TV when using Android, also when using iPhone. Tried three different iPads with the Apple TV and the companion app wonāt display the in game map on any of them. The app launches, the map displays a short moment, and then the app returns to the home screen.
I am running Win 11, CA on iOS15 paired to a first gen Wahoo KICKR and Wahoo TICKR X hr strap and have issues. The issue I am seeing is no BT pairing or registration of those devices through the CA.
I do have an Apple Watch and it does show up as a HRM though I donāt use that as I use the strap for HR and cadence.
I have tried a different iphone and my iPad running the CA there and see the same issues of not being able to see BT devices.
I can also run Zwift from my iPad and all BT devices pair there.
This tells me the CA is the least common denominator here.
Yes I too can run Zwift on the the iPad itself with all BT connections- trainer, HRM and Sterzo without problem.
Still problems with the companion app. Running game on a desktop with win 10 and companion on a Ipad pro. Today i thougt it was fixed, everything looked normal (for 1/2 minute) then the map switched off again in the companion app.
In my situation I have Apple TV running Zwift and was using IPad for the companion app. That is where the trouble began after this latest update of the companion app. The map in the companion app would appear briefly and then disappear. Reinstalled all apps but no change. Used both Ipad 12.9 pro with M1 chip and IPad Air. Both failed. Ironically the companion app does behave when I use it on my iPhone 13 pro. So I donāt think it is related to my WiFi.
No apple watch.
No Apple Watch
Had exact same experience on iphone12 mini as my iPad Pro. Both devices are on 15.1 with the same CA level.
If the zwift app isnāt open both devices run the CA as normal
Apple TV is also fully updated
My iPad also not responding and as of this morning 6/11/21 the zc app has completely packed up the logo icon not even coming up and every time I attempt to uninstall it reappears upon restarting my iPad
See attached image this is all that appears and only on my homepage and not in the list of apps in my settings.
Was working fine on Wednesday evening but then from Thursday morning my ,map refused to open
Companion app map disappearing on multiple set-ups.
Same problem on both set ups when running Zwift on latest Apple TV and prior generation.
Same problem here.
No problems prior to update.
No Apple Watch.
iPhone works but not iPadā¦
Please fixā¦
Had the same issue this morning on my iPad. Very frustrating. And went through all checks - same network, did a reboot of my iPad. Didnāt fix the problem. Then opened Companion app on my iPhone XS and it worked fine. But screen is too small to have same experience as on an iPad.
Same issue for me - no map, and when Iām doing a structured workout, the workout and map pop up for about 1 second and then disappear.
I tried both iPad and iPhone - same issue. Map pops up for a second, then disappears. On zwift, it shows companion app as connected.
The problems with companion app all started straight after I did the update on Thursday Nov 4th. My iPad Pro or my iPhone 10 would not move from Home Screen to game. I deleted Zwift and companion app and reinstated, Apple TV is up to date. Interesting that today the iPhone decided to show me maps after an hour of riding in a group event. !!!
Having the same issue. Starting November 4 iPad companion app will not show map while on Zwift on Apple TV. The map flashes up then disappears and home page appears. Have deleted companion app and reinstalled on iPad no change. Deleted Zwift app on Apple TV reinstalled no change. Apple TV, iPad are all up to date. All running on same Wi-Fi network. For some reason iPhone companion app works! Reported issue to Erin at Zwift support and could not help. Said issue had not been reported which is NOT true as I see on this forum.
Mac OS - 10.15.7 - No Apple watch. Wahoo Kicker 17, Wahoo tickr x, Wahoo cadence sensor - all connected via bluetooth directly (not through iPad or iPhone)
Unable to screen shot - disappearing map. The Companion App on iPadOS looks like the map minimizes and then the Companion App returns to the non-workout screen with Home, Events, Activities, Goals, and More at the bottom.
I have tried to logout of the Companion app and Zwift app on the Mac. This does not resolve the issue.
Yes I have run the Companion App on iOS (iPhone 11) v15.1 ā Works normal. The iPad is on iPadOS 15.1 as well (Broken)
On that white screen on launch symptom: No!!!
Toggling Bluetooth on the iPad does not fix the issue for me.
FYI, this is more than a maps issue. The workout screens do not show on iPadOS.
I prefer to run the Zwift Companion App on the iPad because the screen size is a lot bigger. I wish you had an iPad native supported app instead of having to run the Companion App in zoom mode.
This issue started with the Companion App update to 3.29.0.
Thanks,
Chad
