With the release of Zwift game version 1.54, we’re pleased to announce the next phase of the Climb Portal feature: Elevation Scaling.
This feature allows you to reduce the meters / feet climbed by 75%, or 50%, or increase it to 125% after you’ve ridden at 100% at least once. By changing the elevation, you alter the gradient of the climb. You might remember this formula from geometry class:
- Elevation Scaling directly alters the Rise in this equation.
- A gradient change and corresponding change in resistance are secondary effects.
- The distance of the Portal route does not change.
As you ride the Climb Portal - you’ll see others with an icon that shows if they’re riding at 125%, 75%, or 50%. You may be passing others because you’re a faster climber, they’re using a more challenging setting, or both.
Q: Will the slope of the road look flatter if I reduce the elevation?
A: No. For this iteration in game version 1.54, the slope of the road will look like the full (100%) gradient, but the resistance will match the elevation scale you choose.
Q: Is Elevation Scaling the same as Trainer Difficulty?
A: No. Trainer Difficulty does not change the elevation of the route. The meters / feet you climb are not altered.
Q: What does the Trainer Difficulty setting do on climbs?
A: Trainer Difficulty adjusts the perceived gradient of all routes and worlds by X%. Your smart trainer’s Resistance signal must be paired to Zwift, and used in simulator (SIM) mode for Trainer Difficulty to have any effect.
The default Trainer Difficulty setting is in the middle of the slider at 50%. A 10% hill will feel like 5% while climbing.
If your Difficulty setting slider is set all the way to the right at 100%, the resistance you feel on a 10% climb will be in full force…
Q: What does the Trainer Difficulty setting do on descents?
The resistance value we send to the trainer on downhills is always half of the actual gradient. The Trainer Difficulty default setting of 50% scales that resistance further.
Q: Where do I adjust the Trainer Difficulty setting?
A: In the game’s settings menu. The menu is context-aware, and will show you the Trainer Difficulty once your smart trainer’s Resistance signal is paired.
Q: Will the compounded effects of Elevation Scaling and Trainer Difficulty be felt at the same time?
A: Yes, while riding Climb Portal routes. Elevation Scaling works only while in the Portal.
Q: How will scaled-elevation Portal rides save to Strava?
A: Strava will note that this was a gamified ride, and also note you rode at 50% / 75% / 100% / 125% of the elevation in the activity title.
In Challenges where Strava is the official record-keeper (like the Rapha Festive 500), if you choose a Climb Portal route - ride at 100% or 125% scale. Portal routes correspond to GPS coordinates of the IRL climbs. So that an indoor ride matches the effort on the IRL climb outdoors, the Portal session should be ridden at full elevation in Strava-managed Challenges.
