Zwift installed to a macbook pro. Garmin Cadense and Speed Sensor Easily Detected. Pick a Trainer. The RPM is responding but my AVATAR is not moving.
Hope you can help.
Hope you can help.
is your speed sensor paired?
you need to pair both the speed and cadence
rpm is crank rotations per second
mph is wheel rotations
so in the pairing mode, make sure you have the speed sensor paired. when you pick your power source.
I am on a lemond revolution. Its frame in / no rear wheel. The bontrager sensor is not being picked up, and the gsc10 garmin is. Unfortunately.
After doing some digging, the lemond is pain but it can be done. see below.
http://support.trainerroad.com/hc/en-us/articles/202170460-Lemond-Revolution
